I’m trying to acces the command line on my RPi. However, when I select exit from the power menu, my OSMC does nothing but freeze. So spamming escape does absolutely nothing at all. I used to be able to access it (installed updates through it), but now my OSMC just freezes when I press exit… Anyone know this problem or a fix or something? Or am I just being impatient?
Sounds like you have something installed in Kodi (addon etc) that is causing Kodi to hang on exit…
Two other ways to get a command line are:
a) Boot up and just after the blue OSMC screen appears, hold down the CTRL key on an attached keyboard until you are at a login prompt
b) Connect from another computer using SSH.
Debug logs with Kodi in debug mode may help show why exit is hanging.
