Problems in connecting to wifi
Came rned on the vero tonight and it wouldn’t connect to my wifi. So I went into the my osmc section and tried to connect to my wifi, problem was when it came to entering my password there was no virtual keyboard.
I’ve just ordered a 10m Ethernet cable so hopefully when that arrives I can give it a go again.
What skin are you using ?
No virtual keyboard is nearly always caused by an out of date Skin which is not compatible with Helix.
Aah. I was using osmc skin. Perhaps I should try the kodi skin
The keyboard should be working fine in the OSMC skin.
