Problems with new add on versions. Any way to roll back?
Updated Food Network addon and none of the videos work, get error message. Is there a way to roll back to an earlier version of the addon?
If update doesn’t show you any other version you can install you probably will have to locate/download an older working version and install it not from the repository but from the zip-file.
