Hi all!
I recently bought a OSMC wifi dongle for my RPi1. I installed OSMC again, specifying that the new network would have been a WiFi network (and not LAN anymore) but WiFi dongle is not working properly: when i get into the interface to enable it, I set the checkbox to true but, after a while, it cannot detect any network and it is automatically disabled again.
I tried to work on it using SSH (connamnctl) and using “enable wifi” I can actually enable the interface, but “scan wifi” doesn’t give me any available connection.
Any suggestions?
This is not enough especially when connecting USB Wifi Adapter. The RPi need a stable 2.5A powersupply like the official on from the store Raspberry Pi Power Supply 2.5A - OSMC
Which most likely is also the reason you get this errors
Jun 13 08:30:55 osmc kernel: usb 1-1.2: USB disconnect, device number 11
Jun 13 08:30:55 osmc kernel: rtusb_disconnect: unregister usbnet usb-20980000.usb-1.2
Jun 13 08:30:55 osmc kernel: RtmpOSNetDevDetach(): RtmpOSNetDeviceDetach(), dev->name=wlan0!
