Problems with some Video Files on Vero V
I have a Problem with some Video files. I do not know which Update caused this, but it was working with the same files before, but when I play them now I see this:
The picture fills only halfe of the screen and it is distorted.
the same file worked before one of the last Updates.
What can I do? What data would you need to help me?
I have Access to the device, the file, Everything, just dont know what to do.
Help would be much appreciated.
image960×539 41.4 KB
image1909×1072 241 KB
image996×1444 35.8 KB
Thanks for the infos.
Here are the logs:
https://paste.osmc.tv/vuzuyajamo
I startetd one video file i know does not work, let it run for 15 seconds and stopped the playback.
If i take a screenshot with kodi itself, it looks like this:
On the screen it looks like the photo i send in the first message.
To clarify: the same mkv file worked perfectly before one of the last updates. i watched it on the same setup (VeroV, lg monitor).
i added the mediainfo for the mkv file:
https://paste.osmc.tv/facurawoba.mel
I hope you can help me.
All the best
Looks like you configured screen/picture position corrections. Suggest you reset them.
If you have issues with the picture location disable overscan on your TV
I reset them, but that did not fix the problem.
It’s Not all Video files, Most of them work fine.
Can you please upload fresh debug enabled logs then
So here are the logs. Again I opened one of the files and let it play for approximately 20 seconds.
https://paste.osmc.tv/wurozilepa
