Hi all,
I have just received and set up my Vero V. I’m very happy about being able to play my backed-up 3D rays. Yay.
One minor hiccup is that my projector will not fully shut down and turn off, when the Vero is connected and running. I’d be happy to hear if someone else is experiencing this slight problem - and if there is a solution.
So here is the step-by-step process leading to the problem:
- Watch a movie on projector/Vero
- Turn off projector
- Projector starts shut-down sequence
- Shut-down sequence indicator (in projected image) vanishes after expected time
- Projector becomes irresponsive (i.e. no button on the remote and no button on the projector itself does anything anymore)
- Projector keeps projecting the image
When the projector enters this state, it will (thankfully) still switch off if there is no signal from any connected source - as configured in the auto-off settings of the projector. So this is a work-around.
When I send the Vero into stand-by before powering-off the projector, everything works as expected.
So my speculation is, that the projector sends a power-off signal to the connected HDMI sources when itself tries to power down and somehow the Vero behaves differently from other sources I have connected (bluray player, fire tv stick) and interferes with the expected sequence.
As stated above, there a workarounds (auto-off or adhering to the “correct” order of shutting things down manually), but it would be nice if it worked in any given situation.
All the best
Andreas
P.S. Edited on 07:50 - typo
