My ‘TV’ has disappeared from my main menu.
I use TVHE backend (on Vero4K+) and Tvheadend HTSP client as front end on LAN on Pi.
It was working up until recently. I can configure add-on and see it logging into TVHE backend so i know its alive.
When i enable and disable add-on a progress bar briefly appears at top right hand of screen.
I tried osmc skin, disabling and re-enabling add-on, recreating .kodi profile (mv .kodi .kodi_backup), rebooting etc to no avail.
Do i need to somehow uninstall TVHE client then reinstall?
Logs https://paste.osmc.tv/eqepayuxag
Suggestions very much appreciated.
Cheers, Geoff.
With the OSMC skin you should be able to go into Interface->Skin->configure and edit the main menu. Then maybe if you go back to Confluence you will see a difference.
thanks, i can select PVR & Live TV, and i can see my Recordings but TV guide is empty.
I’ve tried restarting tvhe client, clearing data … restarting, rebooting, reducing update interval for updates (to guide), resetting to default, changing skin and back again to no avail.
Feels like my hvte add on is corrupt … can i go in via CLI to manually remove, then add it again via usual process.
Thanks again, Geoff
I guess if you uninstall it, manually remove pvr.hts from somewhere in /usr/share/kodi and then try reinstalling it from an add-on repo you should get a ‘clean’ version.
fixed. Turned out to be a missed setting in the user’s profile in TVHE server.
Cheers, Geoff.
