I have installed pandas with “sudo apt-get install python3-pandas” on my RPI2
On this device, I have installed python 2.7, 3.4 and 3.5.
I noticed that I can use import pandas from python 3.4 prompt, but not from 3.5.
Have I done something wrong?
Check site-packages.
…and do what?
Except the fact that I can see pandas only in python 3.4, pandas version is 0.14.1, and with
I can’t install more recent version.
What could be the problem?
The latest version of python3-pandas is Debian jessie is 0.14.1-2.
The version available in Debian stretch is 0.19.2-5.1.
Currently, OSMC is still using jessie.
Can I somehow install newest version?
Never mind as stretch is about to come I will just wait for a while. Thanks.
You can install it via pip
That’s quite a big log but it does contain the line:
Successfully installed pandas python-dateutil pytz numpy six
so why do you think it failed?
Because, when I import pandas, its version is 0.14… instead of 0.20
Probably because the version included in Jessie is indeed 0.14.1-2 ?
Edit: Sorry, I didn’t see @dillthedog answer above. You could install it using sid’s repo, but it might bring up unwanted results.
Stab in the dark here but you could try:
sudo pip uninstall pandas
then:
sudo pip install pandas==0.20
or
sudo pip install pandas==0.20.3
Thanks Tom.
It doesn’t work.
What fails?
The installation of pandas==0.20?
Or can you still not import it?
Thanks Tom.
