I’ve seen a few posts describing my problem, but can’t seem to find a solution. Definitely doesn’t seem to be widespread. I can’t find anything out of the norm in my logs.
The video will freeze, then after 7-10 seconds it will fast forward to catch back up. I can stop the video, then resume without problems. Sometimes a video will go 20 minutes, other times it’s 20 seconds before it happens again.
I’m also having intermittent wifi issues. The built-in wifi worked fine for months, then suddenly would not connect at all. I figured out how to use a wifi dongle and things are better, but it will still disconnect randomly. I can’t tell if it’s a hardware issue or not. I haven’t tested using a different OS, which is why I can’t verify if it’s bad hardware. Thanks for your help!
