i just installed osmc on my friends raspberry 3. Now the newer raspberry crashes very often. For example sometimes i try to login via ssh and the raspberry craches directly if i send an command like sudo apt-get update via terminal. I thinks that is very strange and i don’t get an idea where the problem comes from. The raspberry crashed also very often if you stream something from Kodi add ons. With my OSMC config from my raspberry 2 everything works fine. I installed OSMC 12.1.16 via Windows installer on the newer raspberry 3.
On the following link you can view the logs: http://paste.osmc.io/omitikozaj
Maybe someone knows an solution for me.
Thank you very much!
If that resolves the issue re-add your add-ons one at a time until you find the one that causes the problem. If you need to get back to how you are now you can reverse the above by running:
Probably not causing any crash, but if this log is from Rpi3, change your overclock settings back to Normal. As you have it set now, you are underclocking your Pi.
====================== Pi config =================== Ul2H1CLu
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
arm_freq=1000
core_freq=500
over_voltage=2
sdram_freq=500
---------------------- Pi config END --------------- Ul2H1CLu
