no matter what I try I cant find my Qnap NAS Shares (no UPNP nor SMB or anything else).
I tried to add it manually with smb://ipadress/Share β the exact same way as I did on Kodi (Windows).
Can you guys help me with that? Without acessing my NAS OSMC is totally useless
Edit: SOrry didnt get you sent a Link in here! I will check this out now!
Yes I have set up a media center (Kodi on my Windows PC) I also used it with raspbian fine.
Now I use OSMC for Hyperion - thats the only reason why I use it anyway.
I stream high quality media over my wifi just fine to my PC so that should not be the problemβ¦
