Just installed the Nov 15 release on a pi1. I noticed that when I play music, pi hardlocks up (permanent freeze) after about 30 min or so. Doesn’t seem to happen to movie playback. This happens to both of my pi 1. I tried unplug the BT adapter, and then music finally works. Thus I suspect the pi doesn’t have enough juice, and ends in hardware failure
Has this happen to anyone else? The power adapter I’m using comes from a pi1 kit I purchased from Amazon. Since the kit got higher seller rating, I thought I would be getting decent parts. It is 5V 1A output, made in China.
Does anyone uses 2A output adapter for pi 1?
