So, i jvae onstalle osmc on my raspberry pi 2, but i can’t use network, i have read another post similar to this but it’s not my siruation, i am connected to wifi but i can’t download anything, i can connect to it via ssh
If you can connect via SSH, then you have “proved” that the network is working at least to some extent
Is the Pi configured with a DHCP or static address ?
if it is a static address, have you set the correct default gateway ?
Did you read this thread?
I have been searching the threads on connectivity and have yet to see my problem listed.
I started a fresh install of OSMC on my Raspberry pi 1 installing the latest release. I followed the directions for WIFI and password.\
Install goes fine. Able to see the device on my network. Able to ping the RPi. Try to add a repository and I am told that the RPi cannot connect to the server.
SSH into the RPi. Able to ping my WAP private IP and my WAN public IP.\
I am not able to ping 8.8.8.8 nor (and …
Sounds exactly what you are reporting.
If it was DHCP the Pi would not have an IP to allow SSH.
Yes that is my thread.
The closest I have found is someone reporting same issue as me with long times for trace route. He has identified 26% dropped packets. I may have the same issue.
I just got home from a long vacation. I had been running OSMC Alpha 4 on a Model B Pi. It is wired to an Airport express. OSMC and Kodi have been working fine. Watched videos all afternoon.
After the video session I downloaded RC 2 and installed it. It seemed fine. I can SSH into it and connect via SFTP. I copied over the necessary userdata files to connect to my shared MySQL Library and Media files, both of which are hosted on a MacMini.
Unfortunately, OSMC cannot connect to the network, so i…
This is the other thread. Only difference is he is using Pi B and a different wifi dongle. Otherwise same issue.
I know that it’s your thread. My response was in this thread started by @Guitar_Lori
