I have a raspberry pi 3 running OSMC and it reboots it’s self. I get a sad face come up.
I thought I could be over heating so fitted a fan and heat sinks but this didn’t make any difference.
I then tried a full reinstall and again this hasn’t helped.
Would anyone have any ideas what it could be.
Thanks Aaron
reproduce the issue
Assuming this rull reinstall did not include anything that would have added instability, then the majority of the time it is either insufficient power or the SD card.
I am using the power supply that come with it 5V 2.5A. And the SD card is also the one that come with it maybe I should try swapping the SD card. When I did a full reinstall I formatted the card and got the files from the raspberry pi site.
It is not uncommon for power supplies to degrade over time. Having relatively high current devices plugged in can be problematic as well (bus powered hard drives for example. Likewise SD cards don’t live forever. I’m not saying that either of these are defective in your case, rather i’m just pointing out that these are the two items that are almost always at fault absent a software issue.
