Raspberry pi 3 Wi-Fi stops working after sending a few videos over dlna
I have bubbleUPnP/DLNA on my phone.
When I stream a video it works great. Maybe I can even send two. My phone’s default video player’s cast option works too but doesn’t send subtitles. The problem is after viewing one or two videos suddenly it doesn’t respond, same happens to my SSH connection if it is connected while this happens. And the pi itself works and shows WiFi as connected but when I try to re enable it doesn’t show any networks anymore. It stays connected unless I start watching videos over bubbleUPnP or any other apps on my phone. My PC is connected to a different WiFi so I can’t try it!
Rebooting solves the problem but I can’t keep rebooting every two videos :S
To get a better understanding of the problem you are experiencing we need more information, including logs from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us.
Here’s a incredibly long log file :S I only streamed a video :S first one didn’t work :S didn’t try to turn wifi on and off because it would make log even longer!
I had to use dropbox because this website doesn’t allow anything other then jpg
the upload log from the RPi itself gives an error. must be forbidden in my country
So i moved my pi to like 3m away from my router (I have 2 routers connected to two different ISPs. this is the other one. not the one i used when i posted this) and this time it was slow. but it worked. no more DCs! just cache buffer full :S and the video i took with my phone was playing strangely… even while played from a usb drive!
maybe i need to get close!? this is strange because on my Ubuntu mate it works perfectly! and It does stream a few videos without lag. it just suddenly stops working after a video stream doesn’t matter if it’s 2seconds or an hour
OK it was working for a while on both routers and now it’s back to normal! It does the same after a few movies :? Anyone can help? Maybe I’ll buy a USB dongle!! Or a real Chromecast :S
