Recently updated to newest version and anytime I hover over the audio system setting it freezes, whenever it unfreezes there is no drop down list for output options.
Audio does not pass through hdmi or 3.5 mm either.
reproduce the issue
I turned on debug and rebooted twice, and the problem fixed itself it seems.
It now shows the list and both output devices.
