the Raspberry Pi PoE Hat Fan Control has changed after the last update. Before the update the fans were silent and after the update, they are sporadically very loud. Is something changed to the fan control with the update? IS there anything I can do?
I’m using one RPi in my bedroom and now it is not usable anymore.
I’m using the atest OSMC stable release and RPi 3+ and 4.
You can change the temperatures when it comes on to make it less aggressive. You can use the following as a reference but note that you would be putting these settings in config-user.txt with the current builds of OSMC.
Add the following line: deb http://apt.osmc.tv buster-devel main
i had to reactivate the dtparam in the user config. The fan randomly turn on with full speed, even while beeing idle.
If I can help further, please let me know.
