My raspberry pi 3 with kodi 18.7 is crashing every few days:
Crashing explained:
Screensaver: date & time from a few days ago
no reaction on mouse or remote from TV.
connected via putty: sudo reboot not working
systemctl stop mediacenter
systemctl start mediacenter
both not working
only thing that working is pulling out the power adapter en replugging it in.
There was a bug in the My OSMC add-on some time back which caused the file to be modified when you entered the overclocking section even when you did not set any values or tell it to save. This function has since been removed from the add-on so if you edit those out it will not happen again.
I am also experiencing some more often sad face or freezing after installation of last update with Kodi 18.7.
And same problem with freezing also on last version of Libreelec
I have some overclocking for improving of HEVC file playing:
I have these problems mainly on RPi3, but also sometime on RPi3B+ and RPi2
Maybe something in Kodi 18.7 accelerate this problem. Because in Kodi 18.6 was no freezing with these setting
Removing of these setting much improved this problem.
Jan
