Raspbmc: Simplink doesn't work after inactivity
Hi all.
The problem is that I use Raspbmc, and I leave it running, changing “source” to DTT on my LG TV.
When I return on HDMI source, XBMC is freezed for inavtivity, and doesn’t “answer” anymore to my commands.
How can I resolve it? Disabling timeout as extreme solution?
@skr3ch, are you sure that it is freezed or maybe just the CEC link is just not working anymore. Do you have an option to either ssh into the rasbberry or can you connect a USB keyboard and check if it reacts to that input?
Oh yes, it maybe Simplink.
I also tried to disable/enable it, but this doesn’t resolve.
In fact “freeze” doesn’t explain completely the situation.
But isn’t good that I can’t return to hdmi to operate…
is there a way to solve it?
up
Try Settings>System>Input devices>Peripherals>CEC Adapter
Make sure it looks like this…
But … if it is disabled in that screen, it should never works, it’s right?
Mine, works, initially
I’m not advising you to disable it. I’m advising to confirm that it matches this configuration.
Yes, was only to say that mine is 99% active :smile:
I just checked, and all match.
But I also have some more options…
…no more suggestions?
