Rasperry Pi wont connect to monitor
It has been working fine and yesterday when I started it and it was booting up, we had a power outage for about 1 sec. After that it stopped booting. When I say stopped booting, my attached screen is a Samsung smart TV with an HDMI connection.
The TV does not see the raspberry PI, says stuff like: 1) check the cable 2) make sure the device is turned on.
I did all that. The raspberry PI shows a solid red light and a blinking green light. The blinking green light has a pattern (think) of 2 blinks the 4, 4, 4, another 2 but I am really not sure on this.
And I don’t remember what version I am running though I try and keep it updated. It’s a raspberry PI maybe a 4 Some numbers that I see from the microsd card are: 4.019.122-2
And I can see the files on the microsd from my nix box Another poster with a similar problem was asked to post his log and old.log so here they are. kodi.log, the end of the file plus 1 before the last date.
Blockquote
2020-11-27 14:51:35.768 T:1726984416 NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001) 2021-11-29 09:55:33.197 T:1506705632 NOTICE: [ context.venom ] service started 2021-11-29 09:55:33.200 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.settings 2021-11-29 09:55:33.203 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.traktManager 2021-11-29 09:55:33.206 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.clearProviders 2021-11-29 09:55:33.217 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.clearBookmark 2021-11-29 09:55:33.222 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.rescrape 2021-11-29 09:55:33.225 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.playFromHere 2021-11-29 09:55:33.228 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.autoPlay 2021-11-29 09:55:33.230 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.sourceSelect 2021-11-29 09:55:33.236 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.findSimilar 2021-11-29 09:55:33.239 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.browseSeries 2021-11-29 09:55:33.242 T:1506705632 NOTICE: [ context.venom ] menu item enabled: context.venom.browseEpisodes 2021-11-29 09:55:52.095 T:1590632672 NOTICE: [ script.module.myaccounts ] Debrid Account Expiry Notification Service Starting... 2021-11-29 09:55:55.659 T:1515098336 NOTICE: [plugin.video.themoviedb.helper] No JSON object could be decoded 2021-11-29 09:55:58.431 T:1682952416 NOTICE: Previous line repeats 1 times. 2021-11-29 09:55:58.431 T:1682952416 ERROR: CAddon[plugin.video.youtube]: failed to load addon settings from special://profile/addon_data/plugin.video.youtube/settings.xml 2021-11-29 09:56:08.491 T:1256173792 ERROR: Previous line repeats 2 times. 2021-11-29 09:56:08.491 T:1256173792 NOTICE: Skin Helper Service --> Starting WebService on port 52307 2021-11-29 09:56:08.492 T:1607418080 NOTICE: Skin Helper Service --> Skin Helper Service version 1.1.32 started 2021-11-29 09:56:11.749 T:1582239968 NOTICE: [ script.module.fenomscrapers ] Service Started 2021-11-29 09:56:11.749 T:1582239968 NOTICE: [ script.module.fenomscrapers ] CheckSettingsFile Service Starting... 2021-11-29 09:56:11.750 T:1582239968 NOTICE: /home/osmc/.kodi/userdata/addon_data/script.module.fenomscrapers/ : already exists 2021-11-29 09:56:11.889 T:1582239968 NOTICE: /home/osmc/.kodi/userdata/addon_data/script.module.fenomscrapers/settings.xml : already exists 2021-11-29 09:56:11.890 T:1582239968 NOTICE: [ script.module.fenomscrapers ] Finished CheckSettingsFile Service 2021-11-29 09:56:11.890 T:1582239968 NOTICE: [ script.module.fenomscrapers ] Sync \"My Accounts\" Service Starting... 2021-11-29 09:56:13.335 T:1632596192 ERROR: EXCEPTION: Unknown addon id \'service.fanart.proxy\'. 2021-11-29 09:56:14.006 T:1632596192 NOTICE: Git Browser v1.2.2: Service Starting... 2021-11-29 09:56:18.952 T:1582239968 NOTICE: [ script.module.fenomscrapers ] Finished Sync \"My Accounts\" Service 2021-11-29 09:56:20.059 T:1582239968 NOTICE: [ script.module.fenomscrapers ] Addon checking available updates 2021-11-29 09:56:21.338 T:1531883744 NOTICE: plugin.program.autowidget: +++++ STARTING AUTOWIDGET SERVICE +++++ 2021-11-29 09:56:21.550 T:1531883744 NOTICE: plugin.program.autowidget: +++++ AUTOWIDGET REFRESHING NOT ENABLED +++++ 2021-11-29 09:56:21.601 T:1788367072 NOTICE: VideoInfoScanner: Starting scan .. 2021-11-29 09:56:21.602 T:1788367072 WARNING: Process directory \'AutoWidget\' does not exist - skipping scan. 2021-11-29 09:56:21.628 T:1788367072 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00 2021-11-29 09:56:22.268 T:1915925424 WARNING: CGUIMediaWindow::OnMessage - updating in progress 2021-11-29 09:56:25.262 T:1565454560 NOTICE: [ORION 4.3.1]: Orion Service Started 2021-11-29 09:56:27.607 T:1557061856 ERROR: WARNING:root:a 2021-11-29 09:56:27.771 T:1557061856 ERROR: WARNING:root:updating DB 2021-11-29 09:56:29.668 T:1523491040 NOTICE: ###FEN###: Main Monitor Service Starting 2021-11-29 09:56:29.668 T:1523491040 NOTICE: ###FEN###: Settings Monitor Service Starting 2021-11-29 09:56:31.959 T:1565454560 NOTICE: [ORION 4.3.1]: The settings file exists and has not changed since the previous version. Keeping the current file. 2021-11-29 09:56:33.523 T:1523491040 NOTICE: ###FEN###: InitializeDatabases Service Starting 2021-11-29 09:56:34.667 T:1557061856 ERROR: WARNING:root:a 2021-11-29 09:56:34.832 T:1557061856 ERROR: WARNING:root:mode2 2021-11-29 09:56:34.833 T:1557061856 ERROR: WARNING:root:None 2021-11-29 09:56:34.833 T:1557061856 ERROR: WARNING:root:mode 2021-11-29 09:56:34.834 T:1557061856 ERROR: WARNING:root:None 2021-11-29 09:56:34.848 T:1557061856 ERROR: WARNING:root:threading.active_count:1 2021-11-29 09:56:34.849 T:1557061856 ERROR: WARNING:root:threading.current_thread:MainThread 2021-11-29 09:56:34.849 T:1557061856 ERROR: WARNING:root:Thread name is MainThread. 2021-11-29 09:56:34.850 T:1557061856 ERROR: WARNING:root:Fullscreen 2021-11-29 09:56:34.852 T:1557061856 ERROR: WARNING:root:Nextup Service Started 2021-11-29 09:56:37.081 T:1523491040 NOTICE: ###FEN###: InitializeDatabases Service Finished 2021-11-29 09:56:38.256 T:1523491040 NOTICE: ###FEN###: CheckSettingsFile Service Starting 2021-11-29 09:56:38.915 T:1573847264 ERROR: Window Translator: Can\'t find window infodialog 2021-11-29 09:56:40.903 T:1565454560 NOTICE: [ORION 4.3.1]: Orion Service Finished 2021-11-29 09:56:41.337 T:1582239968 NOTICE: [ script.module.fenomscrapers ] A newer version is available. Installed Version: v1.6.0, Repo Version: v2.0.5 2021-11-29 09:56:41.338 T:1582239968 NOTICE: [ script.module.fenomscrapers ] Addon update check complete 2021-11-29 09:56:47.490 T:1582239968 NOTICE: [ script.module.fenomscrapers ] Settings Monitor Service Starting... 2021-11-29 09:56:47.844 T:1218437344 ERROR: Create - Error creating 2021-11-29 09:56:47.918 T:1207693536 ERROR: Previous line repeats 1 times. 2021-11-29 09:56:47.918 T:1207693536 WARNING: Attempt to use invalid handle 2 2021-11-29 09:56:47.935 T:1590632672 WARNING: Previous line repeats 2 times. 2021-11-29 09:56:47.936 T:1590632672 NOTICE: [ script.module.myaccounts ] service stopped 2021-11-29 09:56:48.019 T:1207693536 WARNING: Attempt to use invalid handle 2 2021-11-29 09:56:49.029 T:1523491040 WARNING: Previous line repeats 7 times. 2021-11-29 09:56:49.029 T:1523491040 NOTICE: ###FEN###: CheckSettingsFile Service Finished 2021-11-29 09:56:49.030 T:1523491040 NOTICE: ###FEN###: SyncMyAccounts Service Starting 2021-11-29 09:56:49.416 T:1207693536 WARNING: Attempt to use invalid handle 2 2021-11-29 09:56:50.750 T:1207693536 WARNING: Previous line repeats 3 times. 2021-11-29 09:56:50.751 T:1207693536 NOTICE: [script.module.clouddrive.common][service-source-1207693536]: Service \'source\' started in port 8585 2021-11-29 09:56:52.235 T:1523491040 NOTICE: ###FEN###: SyncMyAccounts Service Finished 2021-11-29 09:56:52.236 T:1523491040 NOTICE: ###FEN###: ReuseLanguageInvokerCheck Service Starting 2021-11-29 09:56:52.251 T:1523491040 NOTICE: ###FEN###: ReuseLanguageInvokerCheck Service Finished 2021-11-29 09:56:52.251 T:1523491040 NOTICE: ###FEN###: AutoRun Service Starting 2021-11-29 09:56:52.261 T:1523491040 NOTICE: ###FEN###: AutoRun Service Finished 2021-11-29 09:56:52.261 T:1523491040 NOTICE: ###FEN###: Clear Subtitles Service Starting 2021-11-29 09:56:52.266 T:1523491040 NOTICE: ###FEN###: Clear Subtitles Service Finished 2021-11-29 09:56:52.266 T:1523491040 NOTICE: ###FEN###: Trakt Service Starting 2021-11-29 09:56:52.290 T:1523491040 NOTICE: ###FEN###: Trakt Service Finished 2021-11-29 09:56:52.290 T:1523491040 NOTICE: ###FEN###: Clean External Sources Service Starting 2021-11-29 09:56:52.935 T:1523491040 NOTICE: ###FEN###: Clean External Sources Service Finished 2021-11-29 09:56:53.049 T:1788367072 NOTICE: ###FEN###: Listitem Monitor Service Starting 2021-11-29 09:56:54.100 T:1876943072 NOTICE: CAESinkPi:AddPackets Underrun (delay:0.00 frames:2205) 2021-11-29 09:56:54.490 T:1640988896 ERROR: Window Translator: Can\'t find window infodialog 2021-11-29 09:56:57.717 T:1915925424 ERROR: Control 52 in window 10025 has been asked to focus, but it can\'t
> Blockquote
kodi.old and it is too big to post all
2021-11-28 09:25:18.293 T:1916543920 NOTICE: ----------------------------------------------------------------------- 2021-11-28 09:25:18.293 T:1916543920 NOTICE: Starting Kodi (18.9). Platform: Linux ARM (Thumb) 32-bit 2021-11-28 09:25:18.293 T:1916543920 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi) 2021-11-28 09:25:18.293 T:1916543920 NOTICE: Kodi compiled 2020-11-26 by GCC 8.3.0 for Linux ARM (Thumb) 32-bit version 4.19.152 (267160) 2021-11-28 09:25:18.294 T:1916543920 NOTICE: Running on Open Source Media Center 2020.11-1, kernel: Linux ARM 32-bit version 4.19.122-2-osmc 2021-11-28 09:25:18.340 T:1916543920 NOTICE: FFmpeg version/source: 4.0.4-Kodi 2021-11-28 09:25:18.340 T:1916543920 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available 2021-11-28 09:25:18.340 T:1916543920 NOTICE: ARM Features: Neon disabled 2021-11-28 09:25:18.340 T:1916543920 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi 2021-11-28 09:25:18.340 T:1916543920 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi 2021-11-28 09:25:18.340 T:1916543920 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons 2021-11-28 09:25:18.340 T:1916543920 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata 2021-11-28 09:25:18.340 T:1916543920 NOTICE: special://envhome/ is mapped to: /home/osmc 2021-11-28 09:25:18.340 T:1916543920 NOTICE: special://home/ is mapped to: /home/osmc/.kodi 2021-11-28 09:25:18.340 T:1916543920 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp 2021-11-28 09:25:18.341 T:1916543920 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp 2021-11-28 09:25:18.341 T:1916543920 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin 2021-11-28 09:25:18.341 T:1916543920 NOTICE: Local hostname: osmc 2021-11-28 09:25:18.341 T:1916543920 NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log 2021-11-28 09:25:18.349 T:1916543920 NOTICE: ----------------------------------------------------------------------- 2021-11-28 09:25:18.376 T:1916543920 INFO: loading settings 2021-11-28 09:25:18.383 T:1916543920 NOTICE: special://profile/ is mapped to: special://masterprofile/ 2021-11-28 09:25:18.455 T:1916543920 DEBUG: CSkinSettings: no tag found 2021-11-28 09:25:18.458 T:1916543920 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml 2021-11-28 09:25:18.458 T:1916543920 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are… 540 720 false 0 30 true 2021-11-28 09:25:18.459 T:1916543920 WARNING: CSettingsManager: missing version attribute 2021-11-28 09:25:18.461 T:1916543920 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml) 2021-11-28 09:25:18.461 T:1916543920 NOTICE: Default Video Player: VideoPlayer 2021-11-28 09:25:18.461 T:1916543920 NOTICE: Default Audio Player: paplayer 2021-11-28 09:25:18.461 T:1916543920 NOTICE: Disabled debug logging due to GUI setting. Level 0. 2021-11-28 09:25:18.461 T:1916543920 NOTICE: Log level changed to “LOG_LEVEL_NORMAL” 2021-11-28 09:25:18.462 T:1916543920 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
The SD card is likely corrupted.
I’d suggest reinstalling from Download - OSMC
