Error installing: Rbp2-mediacenter-osmc (18.4.0-6).
Please report this to the OSMC forum.
What can I do? But please step by step, I’m new here
Thank you.
Thank you.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Seems like you’re on a very old nightly.
Schould I uploaded ‘all configs and logs’ or only GUISettings?
Always all.
This is GUI settings, not all. This is useless, we need to see all.
I’m sorry. https://paste.osmc.tv/ibuguxomoj
SSH into your RPi and run the following…
sudo apt-get clean
sudo apt-get update
sudo apt-get dist-upgrade
What is SSH?
Thank you. Done. How can I logout from SSH? Should I disable Raspberry?
Type “exit” and press enter, but you need a reboot after those commands. Just type “sudo reboot” and enter osmc password if prompted.
Thank you all! It works
