Hello,
A few months ago I changed to shared DB. The DB is running on a linux server under MySQL. I run Kodi on OSMC on two Raspberry PI’s and I also share the DB with Kodi running on 1 Android phone and 2 PC’s.
When an update is available it seems to update most things OK, but the RBPI update doesn’t work. I will enable debug logging to get logs next time it does it. Any suggestions in the meantime?
