I had installed autofs (so I can easily access my shares through the /net directory) on alpha 4 and it was all working fine.
Today, I fresh-installed the RC using the Mac installer on a new SD card and OSMC and Kodi is up and running. I performed a sudo apt-get install autofs and it installed, I enabled the /net -hosts line and rebooted. But it’s unable to access any of the nfs shares. Again - this config worked perfectly on alpha4 on RPi2.
Any thoughts?
Also a bit more info.
my NFS export is on a NAS on my local lan as storage.local - I can mount this just fine with
sudo mount storage.local:/data/Media test
where test is a local directory I made just to test this out. So I know the share is available, I know it can be mounted by OSMC. For some reason autofs doesn’t seem to work in the RC when it did in Alpha4
Exact steps I did:
- Fresh install OSMC on SD
- after booting and selecting language - ssh in
- sudo apt-get update
- sudo apt-get install autofs
- edit /etc/auto.master and uncomment the “/net -hosts” line
- reboot
in alpha4, at this point, I could do:
cd /net/storag.local/data/Media
and it would auto-mount and behave as though it was always there. In the RC, I get
“-bash: cd: /net/storage.local/data/Media: No such file or directory”
the /net directory does exist and the rest of the path is supposed to trigger the nfs mount.
Thanks so much for your help.
Oh am I an idiot…
The line in /etc/auto.master should be
/net /etc/auto.net
and I had it as:
/net -hosts
DOH! Nevermid and so sorry to waste your time!
For anyone searching - here’s how to setup autofs so you can use the /net directory:
- edit /etc/auto.master and uncomment the /net line and make it: /net /etc/auto.net
now you should be able to get to any NFS export like so:
/net/<host>/<share>/
Nice info, I use autofs but when I set it up the tutorial had me creating a auto.nfs file that targets a specific NFS server. I like this way better so I converted my setup to it, it is easier to setup and more versatile.
