I have a bunch of the VRC-1100’s (cheap on amazon, worked well with RASPBMC.)
Unfortunately, so far they don’t work with OSMC. For a start, the volume up/down doesn’t work, or only partially - if I hit vol-up, it says 100%, but vol-down does nothing.
Navigation works fine.
There was a post from a few weeks ago about the VRC-1100, but it didn’t seem to result in any solutions.
Put this in /home/osmc/.kodi/userdata/keymaps/ then reboot and let me know if it fixes it https://dl.dropboxusercontent.com/u/30655053/hama_mce.xml
Thank you, that fixed volume (modulo an extra “>” in the file.)
this works also for logitech and fujitsu keyboars with multimedia keys
Hi - My first post here.
Would you know if this file would also fix the same problem with the iPazzPort Mini Wireless Keyboard? Link: http://ipazzport.com/en_productinfo.asp?id=205
Also - can anyone kindly point me out to a fix for CEC? I have it enabled and yet does not work.
Raspberry Pi2 running OSMC.
