In RC skin, the movie covers (posters?) are missing. Movies are tagged by Media Center Master.
TV shows works fine though.
In confluence both works fine.
The widget uses poster artwork. Best to leave scraping to Kodi to get the correct artwork assigned.
OK, that does not explains why it works with any other skin and not OSMC one.
From what you wrote I understand that I have no change how to display artworks for all my tagged library while using OSMC skin, right?
Other skins may be using different widgets to this one.
ListItem.Art(poster) is what’s used.
Hmmm, I see. I`ll try to add some movies without tags.
Do you thing that this will be solved or only “solution” is retag my whole library?
