Thank you for your hard work OSMC team, and a great release.
I’m having a problem building DNSCrypt on the new RC. I’m not sure if it’s an OSMC or DNSCrypt problem but perhaps somebody have an idea. I had it working on Alpha 4.
./configure gives me the following:
osmc@osmc:~$ tar -xf dnscrypt-proxy-1.4.3.tar.gz
osmc@osmc:~$ cd dnscrypt-proxy-1.4.3
osmc@osmc:~/dnscrypt-proxy-1.4.3$ ./configure
checking build system type… armv7l-unknown-linux-gnueabihf
checking host system type… armv7l-unknown-linux-gnueabihf
checking for gcc… gcc -std=gnu99
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… configure: error: in /home/osmc/dnscrypt-proxy-1.4.3/src/libevent-modified': configure: error: cannot run C compiled programs. If you meant to cross compile, use
–host’.
See `config.log’ for more details
configure: error: ./configure failed for src/libevent-modified**
Prior to this I prepared the system as follows:
sudo apt-get update
sudo apt-get install aptitude
sudo aptitude install gcc libc6-dev wget make dnsmasq dnsutils
wget https://download.libsodium.org/libsodium/releases/libsodium-1.0.2.tar.gz
wget http://download.dnscrypt.org/dnscrypt-proxy/dnscrypt-proxy-1.4.3.tar.gz
I succesfully extracted, built and installed libsodium. Then when running configure for dnscrypt it returns above error.
I’m unable to upload/attach config.log to the forum, but I can email it if interested. It ends thus:
install_sh=’${SHELL} /home/osmc/dnscrypt-proxy-1.4.3/libltdl/config/install-sh’
libdir=’${exec_prefix}/lib’
libexecdir=’${exec_prefix}/libexec’
localedir=’${datarootdir}/locale’
localstatedir=’${prefix}/var’
ltdl_LIBOBJS=’ lt__strl.o’
ltdl_LTLIBOBJS=’ lt__strl.lo’
mandir=’${datarootdir}/man’
mkdir_p=’$(MKDIR_P)’
oldincludedir=’/usr/include’
pdfdir=’${docdir}’
prefix=’/usr/local’
program_transform_name=‘s,x,x,’
psdir=’${docdir}’
sbindir=’${exec_prefix}/sbin’
sharedstatedir=’${prefix}/com’
subdirs=’ src/libevent-modified libltdl’
sys_symbol_underscore=‘no’
sysconfdir=’${prefix}/etc’
target_alias=’’
configure: exit 1
