Can anyone assist a real newbie? I want my Pi running OSMC to read my movies which are on a wired network drive
For a start, I suggest you do a clean install of OSMC RC.
Next, do you have any actual problems and symptoms - I ask because, as asked, the answer must be that you add a network source, and run from there.
Derek
Cheers, will try that today…
