Good morning all,
First of all I want to apologize for my approximate English, I am French and I am speaking to you using an online translator …
I have been using OSMC for a good ten years and had never encountered a video playback problem.
This is because I have a bunch of video file that works perfectly with VLC on my PC and that I can’t play properly with OCMC.
I use OSMC on an RPi2 and on an RPi3, the symptoms are identical: the playback starts, the sound works but the image freezes every three seconds and remains blocked for a few seconds before displaying another passage which is also blocks.
As explained in the Forum, I downloaded MediaInfo and here is the link to the details of the file I’m trying to read:
https://paste.osmc.tv/amenerehuk.tex
I hope the tradiction will work and I thank you for the time you will devote to my problem ![]()
Nicolas
reproduce the issue
upload the log set (all configs and logs!) either using the
That movie is encoded with HVEC Main 10@L4@Main (also known as H.265) which the PI2/3 can not decode in hardware and therefore the software decoding (CPU) will struggle to play that.
So you either have to transcode them with a codec the Pi2/3 can hardware decode or you would need to switch to a Vero4k or Pi4.
Thank you very much for your answers
If the problem comes from my hardware, I must therefore wait for an OSMC version for RPi4.
Thanks again !
Well you could go for a Vero4k+ ![]()
Also there is already a testing version of OSMC supporting the Pi4 that works 90%.
