Hello!
I would like to improve the wifi connectivity of my Vero V, I believe that I have got it as good as it can be using positioning and settings on the access point, however I would like to improve bandwidth further, I think the most sensible way to do this is by simply using a USB wifi dongle with a high gain antenna.
The one I am considering buying is the TP-LINK Archer TXE70UH, it uses a Realtek 8852CU chip.
Is the Vero V compatible with this device? If not could it be made compatible with it?
