Anytime I pause an HD video (TV show or movie) from my library, Kodi reboots. Also, if I try to resume any HD video (from my library), again, it reboots. I have a number of Fire TVs running Kodi and do not exhibit this behavior. I would like to attach the log file but not sure how.
reproduce the issue
upload the log set (all configs and logs!) either using the
The log you posted is empty. Please reboot twice, reproduce the issue, and then upload logs again making sure you select the all logs option.
I followed the instructions, not sure why they were empty, here is a second attempt:
https://paste.osmc.tv/awusibejum
Can you disable the Unpause Jumpback add-on and see if that makes the problem go away.
That seems to have resolved the issue; I thought I tried that before without success, but I am not able to reproduce today. I will re-post if it occurs again, otherwise, we’ll say we have successfully resolved.
