Hi. I’ve had lots of crashing issues lately so reinstalled OSMC which went OK and the crashing seems to have stopped. However, I’ve been using a 4tb HDD with no issues but now the Vero can’t see it. It’s connected via a generic powered hub (I’ve also tested it with an OSMC one) and I just can’t find it anywhere. It’s connected to the USB port closer to the front and my unit has the USB issue so I’m not sure if that’s the problem. Hopefully it’s something simple, but grateful if anyone can help. Thanks.
Can you try the other port on the device and see if this helps?
Does the drive or hub have any lights?
Thanks for the reply. So I think I’ve tested just about every combination going, I’ll describe as best I can; with the HDD connected via the hub into USB3, the Vero only recognises it if I connect it while the power is on. If I then reboot, the Vero doesn’t see it. If I physically remove and reconnect it, the Vero sees it again. With the HDD/hub in USB2, the HDD is seen, and is still there when I reboot the Vero. The USB dongle I use for my keyb/remote never works in USB3. I only tested playback from the HDD on USB2 and didn’t see any issues for the minute or so I tested it.
Edit; just to add I got the same results using both the generic and OSMC hub, which has 4 x USB3 ports and a switch/blue LED for each one. The HDD doesn’t appear to have a light.
This could be difficult to track down but I want to ask one thing.
Does the issue only occur when rebooting while the hard drive is connected?
Does a cold boot (i.e. boot from mains) always guarantee the drive is detected?
If you ditch the hub, what happens? I know this isn’t advised but am wondering if this changes.
If I have the powered hub connected to the USB port to the right (as you look at the RH side of the Vero) and the HDD connected to that, the Vero doesn’t even turn off when I pull the Vero’s power lead out. Same if it’s connected to the left (blue) USB port.
If I software reboot the Vero in that state the HDD is recognised when connected to the RH USB port.
If I remove the USB hub, with the Vero power disconnected the Vero turns off. If I reconnect the hub into the left (blue) USB port the Vero will reboot, with the power to the Vero disconnected. When it reboots the HDD isn’t recognised. If I force a reboot with the software, the HDD still isn’t recognised.
I then removed the hub entirely and connected the HDD on it’s own into the blue USB port, and reconnected the Vero PSU. The HDD was recognised after that first hard reboot, but NOT by subsequent hard reboots or software reboots. If I disconnected the HDD, and reconnect it while the Vero is powered, the Vero picks it up. If I then hard reboot, it doesn’t reconnect.
If I connect the HDD, unpowered, to the RH USB port and software reboot I don’t see a message saying the drive is mounted but I can’t check for sure because I can’t use my Rii remote as the dongle won’t work in the blue USB port. A wired keyboard doesn’t work either and I can’t find the VeroV remote. I’ve tried a 4K remote and the dongle for that doesn’t work in the blue USB port either. If I disconnect the HDD I get a message about unsafe drive removal and when I reconnect it I get a message saying it’s mounted.
The only way I can use the HDD and remote effectively are through the powered USB hub into the RH USB port, and connecting the HDD and remote dongle to that. If I software reboot like this the HDD is always picked. If I hard reboot I have to disconnect the PSU AND hub. I hope that’s made sense.
It’s annoying the HDD does not have a light, as that could be useful during the boot process.
I will think if there’s something that can be done here.
Actually I just checked and it does have one. It’s so small and feint you can hardly see it. The drive is a Seagate Backup Plus portable 4tb. It turns on and off when I turn on/off the switch for the port on the hub.
When the device (Vero) boots, does the LED on the drive change at all?
Yes, it goes off when the Vero powers down, either by being connecting with no hub into USB3 and pulling the power cable out of the Vero, or if I connect it via the hub into USB2 and software reboot, then back on. Another thing I’ve noticed is that some movies on the HDD won’t play through the Movies menu, I get a message saying the file is no longer available, but it is in the HDD and I can only play it via the File Manager menu.
There may be an issue with the USB port. I suggest contacting support@osmc.tv with logs and order number
I already did that months ago, and the response I got was very slow. It was left with you saying I could send it back but you didn’t tell me how long you’d need it for so I gave up. In all honesty, I feel like you should be offering those of us who have this issue a better solution. Someone else mentioned 16 weeks for a turn round time, which is quite ridiculous for a fault that seems to be a design or manufacturing fault. Perhaps a free, or much reduced cost, replacement, and you can repair the returned ones at your leisure and resell them as refurbs. Like I said before, I had a really high opinion of the tech support for Vero kit but that’s mostly gone now. I’ve had mine a little over 2 years and it’s next to useless.
