Hi all.
I need to edit the Advancedsettings.xml file on my PI running OSMC. Before the update I was able to access the share and edit the file that way.
Now i can only ping the box. No shares are available, I cannot access it in any way.
The easy settings addon is not updated, as the location for the settings in the Advancedsettings files has changed with the update.
Thank you
W
If you just need to get in and edit this one file SSH is probably your best bet.
There is a quick guide to editing files here.
If you are interested, there are some other commonly used commands listed here.
