Remote: going to menu and back to video
Hi folks, I m using the vero with the inbox remote. When playing a video and pressing the back key, the video goes to the background and the KODI menu to the foreground. How do I get back to the video?
Didn´t find a topic about this, please move if I missed one.
Depends which skin you’re using, if you’re using the default OSMC skin then you need to keep pressing Back until you get to the main home menu then a further press of Back will take you back to the playing video.
If you’re using Kodi’s default Estuary skin then there’s transport and full screen menu buttons in the View Options menu from any library page.
