I have Logitech Utrax remote with usb receiver. Problem is Enter key doesn’t work, instead I have to use OK key which is not convenient.
Key are recognized by irw as:
It worked “out of box” (minus mentioned key). Selecting different remote in OSMC settings doesn’t make any difference, perhaps my remote isn’t detected as remote after all?
edit: somehow my first post got messed up, Lircmap.xml looks like:
It’s a fantastic addon I just found tonight when I had issues with changing my remote.xml file. What took nearly five hours of research and mucking around I could have done in 5-10min with this app.
It overrides all previous settings you created but keeps them safe as a backup. You select what function you want a key to have and it then asks you what key you want that function to be taken care of.
