I’m coming up short in finding out how to do this. My age is letting me down in figuring out technology I used to be handy with…
Wife bought me Bluetooth ear buds so I don’t have to turn up tv volume so high. I enabled them in our Vero V (My OSMC) and in Kodi Audio Output Device. They are a Godsend…
Is there a way to assign a button on the remote to quickly bring up the Audio Output Device list? The system always defaults back to analog when I put the ear buds away and that’s a good thing, but when I do want to use them it would be nice not to have to dig into system settings.
Cheers,
Robert
I thought the audio output device was automatic and the only change one might need to make is to switch on/off audio passthrough. If this is the case the action id for keymapping is “audiotoggledigital” or if your using the keymap editor add-on it is under the audio section labeled “Toggle Digital/Analog”.
Thank you, I’ll look into that.
Seems to me to always default back to the built in output device when I put the ear buds away. The Bluetooth option disappears from the output options when they are on the charger. And getting them out the option re-appears in the list but it doesn’t automatically switch to them. And I wouldn’t want it to either. I just want a quick way of switching to them when they are available.
Cheers,
Robert
Sorry, I put this thread in the wrong subcategory… this is a Vero V I’m using.
I don’t know anything about key maps. The standard OSMC remote does everything I need between short and long presses. Until now…
Cheers,
Robert
It doesn’t matter as this system works the same AFAIK on all OSMC supported platforms. What I remember from setting this kind of thing up years ago for someone else is that the first time you connect your bluetooth headphones you have to go to the audio settings and change the output device. When you turn off the headphones it automatically switches the output device back to what it was before you connected your headphones. From then on it automatically switched between the two audio output devices whether your headphones were connected or not. If your setup was surround sound and you were using passthrough audio to facilitate that then that is where what I mentioned comes into play as the bluetooth output requires two channel non-passthrough to work.
The keymapping system in Kodi is where you can assign what happens when you press a button on your remote. You have the option of tweaking it if you like.
Another option that you might not be aware of is there exist cheap little optical to bluetooth adapters that you could plug in to your vero as well. The Vero’s actually send audio out of the optical and HDMI at the same time. If connected this way you could listen to your headphones at the same time as your wife and the volume would be completely independent between the two. A buddy of mine recently picked one of these up on Amazon for something like $17 USD. It was super janky with terrible directions but it uses almost no power and it just works. Dude is around 80 and after running it for a couple weeks I haven’t gotten a phone call yet to solve a problem so I call that a successful enough product.
Thank you very much, that’s helpful information. That little optical to Bluetooth might be just the ticket.
I have AVR, just a basic speaker bar connected via HDMI. No pass-through.
A little more reading tells me the audio output device setting cannot be summoned directly via keypress. There are other ways via profiles, but I think you’ve pointed me in a more suitable direction for our needs. Much appreciated!
Cheers,
Robert
