Hi there, my remote doesn’t work anymore. I moved the USB dongle to another USB port but to no avail. I still have not tried with a new battery. Can it be that the battery is depleted in such a short time? What can be wrong? I can still use Yatse to remote control Vero2 but not that convenient.
Which USB port did you put it in?
Do you see a blue light on the front window?
Also try changing the battery. Your post history suggests you received your device 6 months ago and 6 months is the kind of battery life I would expect on the remote with typical use
Hi Sam, I put it in de 1st USB port (right most) but also changed using 2nd port to no avail. However, I don’t see the blue light anymore on the front device. Does it mean the device is faulty? Should I change the battery?
All went well. The remote is working again with a new battery. Nothing wrong with Vero 2. Thank you Sam for your prompt assistance. I panicked, my apology.
No problem – with typical usage you will probably need to replace your batteries every 6-7 months. The good news is that they are cheap batteries – you can find them for about £0.50 each on Amazon.
