OSMC comes with tons of interface languages.
I don’t need that mighty list, just the two I can use.
How do I remove them? All the rest are just clutter.
Thanks!
Thanks!
They can’t be removed from Kodi -> addons -> my addons -> appearance > translations
resource.language.* are located in /home/osmc/.kodi/addons, but I don’t know if it’s “safe” to delete them…
Would also be eager to learn the answer. The language list just clutters the list of Addons.
This behavior is completely dependent on Kodi. You would be more likely to find a relevant answer by seeking support on their forums.
This is so users without a network connection can pick a language in the tutorial.
The language addons are written to the kodi directory with root ownership. Users can’t delete them via Kodi… And they’ll be re-installed after an update.
