For the above, to set up my new V, is it just a case of doing a full backup of the 4K+, then restore onto the V, or are there other issues to consider?
thanks
thanks
If you are not mounting your media disk volumes using, eg, autofs that should do it. You would also have to install any add-ons which are not provided on Vero by default.
thanks Graham - I access all my media via wired network, using SMB, so presumably should be ok?
I believe so, if you are just using Kodi’s file system to access SMB shares.
Yes, but make sure both systems are up to date
Will this copy all addons over too?
If I do a dpkg --get-selection > Installed.txt and then use that list to install any non installed packages on the V if I can get SSH to work?
This will break your system as it will install Vero 4K specific packages.
The backup should copy the add-ons from the local Kodi directory, yes
I did dpkg --get-selections > installed.txt on both devices and then used the diff command with grep “<” to list all packages that weren’t already installed and came up with this list:
avahi-utils install <
dirmngr install <
e2fslibs:armhf install <
fdisk install <
gcc-8-base:armhf install <
gnupg install <
gnupg-l10n install <
gnupg-utils install <
gpg install <
gpg-agent install <
gpg-wks-client install <
gpg-wks-server install <
gpgconf install <
gpgsm install <
iw install <
libapt-pkg5.0:armhf install <
libassuan0:armhf install <
libcomerr2:armhf install <
libfdisk1:armhf install <
libgcc1:armhf install <
libksba8:armhf install <
libldap-common install <
libncursesw5:armhf install <
libnpth0:armhf install <
libtinfo5:armhf install <
libusb-1.0-0:armhf install <
libustr-1.0-1:armhf install <
multiarch-support install <
pinentry-curses install <
Just a case of installing the packages you need from this list.
Why not just start to use the V and when you find something that doesn’t work, install whatever it needs?
It was just a way of finding out what I had installed before. I haven’t installed any of those packages, but on a previous run of the command it picked up autofs, bash-completion and locate which I did install.
For future reference: APT history.log should let you see what you have installed yourself.
If some packages weren’t installed by yourself but picked up, they will be picked up again as dependencies if needed.
ok, backed up my 4k+ to a network drive, & copied that to USB stick. If I put this in my V, how do I access that for a restore (is it home or root, or a sub-dir)?
thanks
Should be /media/<stickname>/<backupfilename>
thanks Graham, perfect!
