Well mine was working with the patched version,but a couple of days ago OSMC was updated and it stopped to work,i had to do the mentioned steps again and it works fine again.They are many patches around,but like i said before "The best way is to compile the librtmp with all patches like described here Customized rtmpdump binaries with patch file all credits go to KSV
Its not the same as this one Patch.diff and compared with the command diff -b -i -y Patch.diff Patch2.diff(where Patch2.diff is your version shows the differences)
Forgive me if im way off the mark here but for my own observations and logic Its my understanding that the librtmp.so.1 file located in /usr/lib/arm-linux-gnueabihf/ doesnt change and is static ?
however the librtmp.so.1 file locacted in usr/lib does. I checked the physical size after Sams patches and saw that it increased in size (similar to the one i compiled a few days earlier)
Ive not personnally had a stream that doesnt work so i cant comment, also before sam included the patches i had already replaced both files as i was unsure what file was used.
Are saying that you replacing the rtmp in the arm-linux-gnueabihf each time ?
Hi aporeg
I Have a Pi 2 with OSMC. I want to replace librtmp.so.1, but i don’t feel to compile it by myself successfully.
Can you give me a funcional link for your last version please ?
thanks for the help.
