Hi everyone,
I own 3 Raspberries (Vers. 2), I set them up the same way, however I encounter the issue that my repos, hence my addons, won’t update after the startup as I am used to it.
- “Automatic updates” is switched on (in the addon section)
- I am able to reach all of the repos manually
- I deleted the “addon20.db” or “addon19.db” in the “database” folder, but it doesn’t seem to fix my issue.
My Kodi’s installed on a Windows system (again exactly the same setup) update automatically (don’t have the issue).
This is why I assume it would be an issue with OSMC… all devices are connected via cable and are updated.
Anyone has any thought on this or has had similar problems?
Thanks!
