Hello,
I installed last kernel. now the max resolution I can set is 1920x1080. With higher like 3840 I only get a blue screen…
Do you are aware of this?
Thx
Kai
Hello,
Thx
Kai
You shouldn’t set a 4K resolution on Vero 4K / Vero 4K +
Enable Adjust Refresh Rate and set it to 1080p. When you play 4K content, it will switch automatically.
ah, ok. for what reason is it not recommended to set a 4k resolution?
ok, thx for explenation. should the refrsh rate set to always?
I recommend doing so, yes.
