Resuming or skipping causes sad face
Hello
I have applied the latest update which went smoothly. However, I do have 3 problems with the vero 4k which may or may not be interrelated:
1. Resuming a film causes it either to crash back to the interface or show the sad face [the problem described in this post]
2. Can’t stream anything live from youtube (like the euronews live stream)
3. Bluetooth won’t connect to my headphones. BT implementation was always flaky, but even worse since the update
Since the update, a variety of films will crash when they are resumed. The do work fine when started from scratch.
System:
  • Vero4k latest update
  • QNAP TS253A
  • Wired ethernet
  • HDMI into a sony TV
https://paste.osmc.tv/ojunogibak
Starting the movie from scratch then skipping ahead also causes it to crash.
Any ideas of what to try?
20:13:02.138 T:3255350016    INFO: CFileCache::Process - Source read didn't return any data! Hit eof(?)
20:13:02.146 T:3255350016   ERROR: Read - Error( -1, 103, Software caused connection abort )
20:13:02.146 T:3255350016   DEBUG: CFileCache::Process - Source read returned a fatal error! Will wait for buffer to empty.
I suspect local playback would not give these issues.
