Hi, Installed the November 20 Update (from Oct 20) and now the IR remote has stopped working - it was previously working fine
OSMC Nov 20, RPi2, RC6-MCE remote, TSOP4838 gpio pin18
Does anyone else have an IR issue with this update? Thanks
From which version did you upgrade?
Some logs would be useful.
It was from a fresh install of Oct 20, I will post the logs shortly. Thanks
Same Problem. Update from Oct. 2020 to Nov 2020
Have a nice day, Ernesto
Addendum: I have restored the backup of the October version, now everything works fine again
root@osmc:/home/osmc# more //boot/config.txt
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
gpu_mem_256=112
sdtv_aspect=1
gpu_mem_512=144
arm_freq=1400
core_freq=400
sdram_freq=400
max_usb_current=1
dtoverlay=gpio-ir,gpio_pin=18
root@osmc:/home/osmc# dmesg |grep lirc
root@osmc:/home/osmc# journalctl |grep lirc
Nov 26 10:37:01 osmc log2ram[202]: lircd
Nov 26 10:37:03 osmc systemd[1]: Starting eventlircd remote support...
Nov 26 10:37:03 osmc systemd[1]: Started eventlircd remote support.
Nov 26 10:37:07 osmc sudo[557]: root : TTY=unknown ; PWD=/ ; USER=osmc ; ENV=LIRC_SOCKET_PATH=/var/run/lirc/lircd ; COMMAND=/usr/lib/kodi/kodi.bin --standalone -fs
root@osmc:/home/osmc# ir-ctl -f
/dev/lirc0: cannot open: Datei oder Verzeichnis nicht gefunden
root@osmc:/home/osmc# lsmod |grep lirc
root@osmc:/home/osmc# uname -a
Linux osmc 4.19.122-2-osmc #1 SMP PREEMPT Sat Jul 4 02:39:56 UTC 2020 armv7l GNU/Linux
root@osmc:/home/osmc# ps auxwww |grep lirc
root 313 0.0 0.0 1932 596 ? Ss 10:37 0:00 /usr/sbin/eventlircd --evmap=/etc/eventlircd.d --socket=/var/run/lirc/lircd -f
root 557 0.0 0.3 9684 2856 ? S 10:37 0:00 sudo -u osmc LIRC_SOCKET_PATH=/var/run/lirc/lircd /usr/lib/kodi/kodi.bin --standalone -fs
root 1076 0.0 0.0 6828 596 pts/0 S+ 11:00 0:00 grep lirc
root@osmc:/home/osmc# systemctl status eventlircd.service
â—Ź eventlircd.service - eventlircd remote support
Loaded: loaded (/lib/systemd/system/eventlircd.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-11-26 10:37:03 CET; 24min ago
Process: 249 ExecStartPre=/bin/mkdir -p /var/run/lirc (code=exited, status=0/SUCCESS)
Process: 314 ExecStartPost=/bin/sh -c for f in /var/run/lirc/lircd-*.sh; do if [ -e $f ]; then s=$(basename $f .sh | sed 's/lircd-//g'); systemctl start
Main PID: 313 (eventlircd)
Memory: 404.0K
CGroup: /system.slice/eventlircd.service
└─313 /usr/sbin/eventlircd --evmap=/etc/eventlircd.d --socket=/var/run/lirc/lircd -f
What’s the output of lirc-lsplugins | paste-log ?
root@osmc:/home/osmc# lirc-lsplugins | paste-log
https://paste.osmc.tv/omequnopiz
# Driver Flags Plugin
accent --- /usr/lib/lirc/plugins/accent.so
atilibusb --- /usr/lib/lirc/plugins/atilibusb.so
atwf83 --- /usr/lib/lirc/plugins/atwf83.so
awlibusb --- /usr/lib/lirc/plugins/awlibusb.so
bte --- /usr/lib/lirc/plugins/bte.so
commandir -as /usr/lib/lirc/plugins/commandir.so
creative --- /usr/lib/lirc/plugins/creative.so
creative_infracd --- /usr/lib/lirc/plugins/creative_infracd.so
default --- /usr/lib/lirc/plugins/default.so
devinput --- /usr/lib/lirc/plugins/devinput.so
dfclibusb --- /usr/lib/lirc/plugins/dfclibusb.so
ea65 --- /usr/lib/lirc/plugins/ea65.so
file -as /usr/lib/lirc/plugins/file.so
girs -as /usr/lib/lirc/plugins/girs.so
asusdh --- /usr/lib/lirc/plugins/hiddev.so
bw6130 --- /usr/lib/lirc/plugins/hiddev.so
dvico --- /usr/lib/lirc/plugins/hiddev.so
macmini --- /usr/lib/lirc/plugins/hiddev.so
samsung --- /usr/lib/lirc/plugins/hiddev.so
sb0540 --- /usr/lib/lirc/plugins/hiddev.so
sonyir --- /usr/lib/lirc/plugins/hiddev.so
irlink -a- /usr/lib/lirc/plugins/irlink.so
irtoy -as /usr/lib/lirc/plugins/irtoy.so
livedrive_midi --- /usr/lib/lirc/plugins/livedrive_midi.so
livedrive_seq --- /usr/lib/lirc/plugins/livedrive_seq.so
logitech --- /usr/lib/lirc/plugins/logitech.so
mouseremote --- /usr/lib/lirc/plugins/mouseremote.so
mouseremote_ps2 --- /usr/lib/lirc/plugins/mouseremote.so
mp3anywhere --- /usr/lib/lirc/plugins/mp3anywhere.so
mplay --- /usr/lib/lirc/plugins/mplay.so
mplay2 --- /usr/lib/lirc/plugins/mplay.so
pcmak --- /usr/lib/lirc/plugins/pcmak.so
pinsys --- /usr/lib/lirc/plugins/pinsys.so
pixelview --- /usr/lib/lirc/plugins/pixelview.so
silitek --- /usr/lib/lirc/plugins/silitek.so
slinke -a- /usr/lib/lirc/plugins/slinke.so
srm7500libusb --- /usr/lib/lirc/plugins/srm7500libusb.so
tira --s /usr/lib/lirc/plugins/tira.so
tira_raw -a- /usr/lib/lirc/plugins/tira.so
udp -a- /usr/lib/lirc/plugins/udp.so
uirt2 --- /usr/lib/lirc/plugins/uirt2.so
uirt2_raw -as /usr/lib/lirc/plugins/uirt2_raw.so
usb_uirt_raw -as /usr/lib/lirc/plugins/uirt2_raw.so
usbx --- /usr/lib/lirc/plugins/usbx.so
zotac --- /usr/lib/lirc/plugins/zotac.so
# Flags:
# E: Empty: Plugin loaded OK, but is empty (is this a plugin?).
# F: Fail: Plugin failed to load (unresolved references?).
# a: Any: Driver can be used with any remote or capture device.
# s: Send: The driver can send data.
#root@osmc:/home/osmc#
Also the output from:
systemctl status lircd_helper@lirc0 | paste-log
#root@osmc:/home/osmc# systemctl status lircd_helper@lirc0 | paste-log
https://paste.osmc.tv/uwomubebeg
â—Ź lircd_helper@lirc0.service - lircd remote support
Loaded: loaded (/lib/systemd/system/lircd_helper@.service; static; vendor preset: enabled)
Active: inactive (dead)
Nov 26 12:51:39 osmc systemd[1]: /lib/systemd/system/lircd_helper@.service:6: PIDFile= references path below legacy directory /var/run/, updating /var/run/
Nov 26 12:51:44 osmc systemd[1]: /lib/systemd/system/lircd_helper@.service:6: PIDFile= references path below legacy directory /var/run/, updating /var/run/
How about:
ls -al /dev/lirc*
root@osmc:/home/osmc# ls -al /dev/lirc*
ls: Zugriff auf '/dev/lirc*' nicht möglich: Datei oder Verzeichnis nicht gefunden
I have a solution.
Thanks, that has narrowed the problem down.
This should now be solved, simply check for updates again.
osmc@osmc:~$ ll /dev/lirc*
crw-rw---- 1 root video 243, 0 Nov 26 13:58 /dev/lirc0
This was fast
Thank you very much!
Confirming all fixed here now also - Thanks everyone
Edit: My resident Crash Test Dummy’s (Kids) will hit the system hard this weekend
The problem was indeed solved in a very short time. Chapeau! Remote control works again. Thanks
