Hi, when installing new update ("a new version of Kodi has been downloaded, do you want to install" => Yes) the system shuts down and power cycle needed to restart RPi. Update however failed.
When then running apt-update and dist-upgrade via ssh (putty), putty session terminates at preparing unpacking mediacenter-skin-osmc_18.0.0-6_all.deb …
Power cycle needed to boot RPi.
Building dependency tree Reading state information...
Done Calculating upgrade...
Done The following NEW packages will be installed:
libaacs0
armv7-eventlircd-osmc armv7-libbluray-osmc base-files base-files-osmc dns-root-data libmariadbclient18 libnss-myhostname libpam-systemd libpng16-16 libsmbclient libssh2-1 libsystemd0 libudev1 libwbclient0 linux-libc-dev mediacenter-addon-osmc mediacenter-skin-osmc python-pip python-pip-whl python-samba rbp2-mediacenter-osmc samba samba-common samba-common-bin samba-libs systemd systemd-sysv tzdata udev unzip wget wpasupplicant
32 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed.
Need to get 0 B/122 MB of archives. After this operation, 5958 kB disk space will be freed. Do you want to continue? [Y/n]
Extracting templates from packages: 100% Preconfiguring packages ...
(Reading database ... 39236 files and directories currently installed.)
Preparing to unpack .../mediacenter-skin-osmc_18.0.0-6_all.deb ...
Progress: [ 0%] [..........................................................]
'putty session terminated unexpectedly
with debug logging enabled (+reboot) using manual install update via My OSMC, same issue.
log files uploaded : https://paste.osmc.tv/ayuhinotiz
Any suggestion how to resolve this appreciated
