Hi!
Sometimes rpi1 boots to an non fully functional state. It shows the screen at 480 resolution and CEC mode is no responding. I can connect to it via SSH and do a restart but kodi.log and dmesg logs show nothing at normal log level.
Any indication about that error?
Thank you!
osmc is fully updated, acts as a osmc mysql client of another osmc rpi3
Also make sure you are powering on your Pi AFTER your TV is both switched on and set to right input for the Pi.
If you ever power on the Pi (including doing a reboot) without the TV (including AVR if used) being powered,
it may result in the EDID being unable to be read, resulting in incorrect resolution and no CEC until the next boot.
