I just updated my rpi2 to latest kodi 15.1 and kernel 4.1.5-1.
It seems that audio passthrough for AC3 and DTS does not work any more.
Also, if I disable AC3 and DTS, kodi does not decode all audio channels. I can hear the music of the movies, but not the voices (like the center channel is not decoded).
Device: Rapsberry Pi 2
Installation media: NFS root (/boot on sdcard of course)
Connection: Wired
Power Supply: 2.1A
Peripherals: WiFi RT5370 for hostapd (tried without it and without running hostapd - same problem)
Storage: NFS
OSMC version:
PRETTY_NAME=“Open Source Media Center”
NAME=“OSMC”
VERSION=“August 2015”
VERSION_ID=“2015.08-1”
ID=osmc
ID_LIKE=debian
XBMC version:
06:14:32 62.988953 T:1956331520 NOTICE: Starting Kodi (15.1). Platform: Linux ARM (Thumb) 32-bit
06:14:32 62.989014 T:1956331520 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
It is connected to an LG Smart TV.
The media player of the TV can play the same file, distributed via DLNA through the same Pi 2, so yes I believe the TV supports that file. Also, the same file plays fine on osmc with the July version.
The debug log includes my entire media library. I prefer not to post it…
Which parts are important for you?
