hi guys! i have osmc installed on a rpi2 with samba server up and running, loving it so far! however, when connecting to the server using my mac, i can only see media folders named movies, music, etc, but all of them are empty and i cannot see my usb hard drives! i have been researching the web for hours but can’t find a soulution, would you please help me out? thanksss
On the pi, can you see the drives mounted in /media?
yes, I can. My movie library has been updated with all my movies in the drive. however, I still have plenty of movies in my mac that I can not get to transfer to de pi. It is incredibly upsetting. thanks a lot for your help!
Please post the output of the following commands:
sudo journalctl | paste-log
sudo net usershare info | paste-log
I’m having the same problem…
Outputs to commands are:
http://paste.osmc.io/cenojoveco
http://paste.osmc.io/qilayenapi
Your second log link does not work. Please try to post that one again.
I see pages and pages of the following error:
Nov 04 19:50:01 osmc kernel: CIFS VFS: cifs_mount failed w/return code = -6
Nov 04 19:50:01 osmc mount[586]: mount error(6): No such device or address
Nov 04 19:50:01 osmc mount[586]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
Nov 04 19:50:01 osmc systemd[1]: mnt-shared.mount mount process exited, code=exited status=32
Nov 04 19:50:01 osmc systemd[1]: Failed to mount /mnt/shared.
Nov 04 19:50:01 osmc systemd[1]: Unit mnt-shared.mount entered failed state.
Nov 04 19:50:01 osmc mount[592]: Retrying with upper case share name
Nov 04 19:50:01 osmc mount[592]: mount error(6): No such device or address
Are you trying to mount a cifs mount in fstab ? What does your fstab file look like ?
