RPI2 - WiFi dongle advice and Confluence availability
Hi folks,
As the title suggests I have bought a Raspberry Pi 2 and I have two questions:
  1. Can someone please recommend a rock solid and fast WiFi adapter that works great with OSMC?
  2. Is there an easy way to switch to the original Confluence skin? If there is, does using Confluence impose any limitations with regards to OSMC-specific functionality (settings, etc)?
Thanks a lot in advance!
Best regards,
Reinis
Cant help withthe Wifi, but skin:- settings > appearance > confluence
Sure – you can do so from Settings -> Appearance
None whatsoever – My OSMC will work fine under any skin. If it doesn’t, do let us know.
Shameless plug: our store is back in a couple of days, and all WiFi dongles we sell obviously work with OSMC.
There are several thread on wifi suggest you search the forum
