Need some help or ideas here. I’ve looked everywhere for a permanent solution and so far have had no luck. Built-in bluetooth is problematic, but this is my walkaround:
Added sources to /etc/apt/sources.list for pi-bluetooth:
deb Index of /debian jessie main staging
deb-src Index of /debian jessie main staging
Order of steps required after every reboot:
sudo apt-get install pi-bluetooth //(yes, eyery reboot)
sudo systemctl daemon-reload
sudo service bluetooth start
sudo rfkill unblock all //(soft block by default on boot)
sudo bluetoothctl
-># power on
-># agent on
Only after doing this, everything bluetooth related works. But all of this is required after every reboot.
Thoughts/Ideas?
