Hello,
I’m using pvr IPTV simple client and I’m facing a possible bug: when using arrow keys to change channel (through a remote), if I hit up or down 2 times to skip 2 channels, I get the sad face screen and then hitting enter brings me a shell with “OSMC login:” prompt.
Not happening with only 1 up/down key hit.
I think is OSMC bug because same configuration with libreelec and Kodi on PC does not have this problem.
reproduce the issue
upload the log set (all configs and logs!) either using the
I am unable to upload log file with OSMC uploader, when I try I get a wrong url (ending with instead of the usual code), if I use the Copy to SD function and then directly upload them here would be ok? Also I think you need to check the old log, because after the sad face OSMC soft reboots.
Anyway if uploading is ok where would I find the logs copied to SD?
Thank you
/boot/
You also can try to just upload the kodi.old.log via paste-log .kodi/temp/kodi.old.log
